Windscreen Washer
After having the third washer pump fail in as many years [all were aftermarket versions including the original one I changed] I am looking for the correct Citroen part number to order in the hope it will last a bit longer. Had a look on the net but cannot seem to narrow it down to a single part number, so can anyone post the correct part number for the double outlet pump for 2009 Berlingo Multispace [B9]. Thanks.
(26-03-2021, 09:46 PM)Multispacer Wrote:  After having the third washer pump fail in as many years [all were aftermarket versions including the original one I changed] I am looking for the correct Citroen part number to order in the hope it will last a bit longer. Had a look on the net but cannot seem to narrow it down to a single part number, so can anyone post the correct part number for the double outlet pump for 2009 Berlingo Multispace [B9]. Thanks.
Answering my own question the p/n for mine is 6434 98
Last Post: Triggermann
Today 01:47 PM
Today 12:50 PM
Yesterday 12:17 PM
Last Post: wbchevron
Yesterday 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
