Threads: 7
Thanks Received: 11 in 4 posts
Thanks Given: 6
I need to lower the subframe in way off changing the saw bar rubber bushes.
Untill removal evrething fine, however by reading the repair manual from the maker it has a special tool witch are a pair of pins for subframe aligment before thitning the bolts.
On haynes manual is writen to do some markins before removal, but i would like to do right think by placing the pins.
Does anyone knows where to get/buy this sort of aligment pins???
Online i can only find for ford, vw and not for peugeot partner/berlingo......
I appriciate your help
Threads: 29
Thanks Given: 67
20
Threads: 75
Thanks Given: 223
164
03-04-2021, 09:15 AM
(This post was last modified: 03-04-2021, 09:16 AM by Sol.)
What Frenchie means, is the part is called a sway bar, not a saw bar. Sway is to move, saw is to cut
Threads: 7
Thanks Given: 6
Ok is sawy, fine
Iam still looking for the pins
Threads: 75
Thanks Given: 223
164
Sway lol. Hope you find the pins. Searching may be easier using the word "sway" in Google or eBay.
Threads: 44
Thanks Given: 97
28
Can you post a picture of the special tool?
Maybe you can make one if it is only a bar with 2 pins in it?
Try the Haynes method as an experiment only and see if it works. If it does, you can forget pins.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Threads: 75
Thanks Given: 223
164
Hey good for you. And sorry for our corrections, they were meant in a friendly way. My Portuguese is non existent!
