1.6 BlueHDI maintenance intervals and how to
Heart
Because I don't have a book with the service maintenance intervals and what needs to be changed or verified, I'm asking here for some details.
I know that the engine oil and oil filter needs to be changed every 10k kms or 12months, what is the recomended engine oil and filter?
Also the brake fluid and power steering fluid needs to be changed every 2 years? But what fluids I need? An what is the procedure? How to drain old ps fluid and replace with new?
The air filter and cabin filter needs to be changed also every year?
How about the diesel/fuel filter?
If you like gaming visit GameForest
Hi
My Citroen Multispace is 2017 Blue HDI like your Pug Partner. The following info is for what is referred to as normal use, not 'arduous conditions of use'. Arduous is defined in a number of ways but includes Taxis, permanent door to door and repeated short journeys - less than 6 miles.
You are correct that the replacement brake fluid is recommended every two years, mileage doesn't seem to be an issue. Sorry, no idea what fluids but that should be easy to find. I don't mess with the brakes so I can't help about the actual procedure but there's many on here that could do it with their eyes shut !
Engine service, referred to as systematic operations is every 16000 miles or annually. I presume this to be engine oil and filter change. Authorised engine oils - 00W30 B71 2312 (C1C2) - EM : 00W30 B71 2312 - Whatever the hell all that means.
Replacement of passenger compartment filter is also every 16000 miles or two yearly.
Your diesel oil filter should be replaced every 32000 miles or 4 years. I've just done mine 'cos it's 2017 but only 23000 miles. Engine air filter is 32000miles or 4 years, again, I'm just going to do mine. You don't say what your mileage is so I've included a couple of other bits.
My own methods will see my oils replaced much earlier than suggested in the information Citroen provide but that's just me, was brought up under my father's Vauxhall Victor !
Hope this might help in some way, all above lifted from Citroen headed information from my dealer.
2017 Multi space 'Feel' - 1.6hdi Blue
[-] The following 1 user says Thank You to Aigburth Lad for this post:
  • deejay_xb
(04-04-2021, 04:05 PM)Aigburth Lad Wrote:  Hi
Hi, my car has 47000 km.
I found out that the engine oil is QUARTZ INEO FIRST 0W-30, about 5l needed.
Do you know when power steering fluid needs to be changed?
What brand of filters have you used?
Most vehicle manufacturers appear not to specify a mileage for change of power steering fluids. On the Citroen Service Schedule documentation, power steering fluid does not get a mentiuon, more or less everything else does. ( For example the check of the PH content in the coolant at 4 years). However, I will potentially change mine at 50k just because I like to keep my cars well serviced. Dealer says it's probably unnecessary. There's others on here who know more than me about that for sure.
I have used Citroen filters at all times except that I will likely replace the air filter with something decent, perhaps K&N or something else.
You are bang on the mileage and age of vehicle where you need to do the diesel fuel filter and air filter.
Ok, thanks for all the info, I will change the oil + oil filter, the diesel fuel filter, the engine air filter, the cabin air filter and the brake fluid.
I will leave alone for now the power steering fluid Smile
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
