Engine cuts out
Now and again engine cuts out all lights come on turn ignition off and back on and restarts no problems, might happen every couple of months, anyone had this, it's a 1.6 hdi 07 plate van
And then wait and restart again, you have to check with a obd reader, by 5euros you can by on ebay and check the ECU errors......
(02-04-2021, 07:54 AM)Daveg Wrote:  Now and again engine cuts out all lights come on turn ignition off and back on and restarts no problems, might happen every couple of months, anyone had this, it's a 1.6 hdi 07 plate van
My van is same engine, same year and I have had that problem! After many months of investigation, no answers. Had loads of things replaced.
Having said that, it has been running ok for a few months now but now starting to wonder if it's the fuel pick up pipe in the tank as it used to happen if fuel went under a quarter of a tank and going up or down steep hills etc.
I keep the tank topped up so hopefully it will be ok for a while.
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
