[Engine] Oil filler cap dw8
Could someone tell me if there should be a rubber ring inside the rim of the engine oil filler cap. When the cap is tightened on this one it loosens again. I can buy a new cap on ebay for a around a fiver but it doesn't come with any sort of seal. Just wanted to confirm if there should be one. Many thanks
I do not exactly know for the dw8, but on the 1.6HDi there definitely is a rubber ring/seal. I am almost certain there needs to be one for the dw8, otherwise plastic on plastic it will not make a good seal and oil will weep everywhere.
[-] The following 1 user says Thank You to saskak for this post:
  • Kieron G
Thanks. Yes I think if there was a ring in the cap it would stop it from overtightening and going loose again. I'll see about finding one
I had a look at mine and, as per saskak's comment, there is a rubber seal.  I couldn't see it at first as it seemed to have stuck to the cap, but it lifted off when I prised a screwdriver under it - pic attached.
Attached Files Thumbnail(s)
[-] The following 1 user says Thank You to notsofast for this post:
  • Kieron G
Thanks for posting that picture to clarify what we thought. There are a load of bits I need from a scrapyard or someone breaking an M49 so will add it to my list
Wire through bulkhead
Last Post: Jakejjt
Today 05:25 PM
Loose tailgate spoiler
Today 04:52 PM
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
