[Engine] Broken Timebelt
Hi I have a Berlingo 2009 1,6 hdi. The timebelt has broken and the timing between camshaft and crankshaft is out of position. Who can I get this in right place again?
I have tried to find the hole in the flywheel but there is several hole and none of them works, the crankshaft stop in something.
I have changes all the damage parts, it was the valve rocker arms.
If the timing belt broke when the engine was running you will have serious engine damage bent inlet & exhaust valves.
The cylinder head will have to be removed to assess the damage.
(06-04-2021, 08:28 AM)jj9 Wrote:  If the timing belt broke when the engine was running you will have serious engine damage bent inlet & exhaust valves.
Hi I have checked the valves and they are ok. And I have changes the valve rocker arms.
I think the timing / locking hole for the crankshaft / flywheel is by the end of the sump, above the exhaust pipe. But if the crankshaft will not turn, it is probably a piston getting stuck against a valve.
Do not turn the camshaft backwards.
(06-04-2021, 10:45 AM)cancunia Wrote:  I think the timing / locking hole for the crankshaft / flywheel is by the end of the sump, above the exhaust pipe. But if the crankshaft will not turn, it is probably a piston getting stuck against a valve.
Hi I am thinking the same ,but how can I adjust / find the right position for the for this camshaft . crankshaft and flywheel? Like I told earlier the timebelt was broken and all got out of positions.
Have a read through this thread....
https://www.berlingoforum.com/thread-20842.html
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
