Alternator overcharging?
Hi Folks,
2017 Berlingo owned for 4 months - battery just died, notice from service history was replaced new 11 months ago. (Yuasa)
After fitting replacement, checked charging voltage, and appears to be continually 14.95V to 15V, measured with with good voltmeter.
Seems too high to me, and thinking this may have caused the early demise of the previous battery?
Am I looking at replacement alternator or regulator, or is there anything else that could be causing this seemingly high voltage?
Finally, it is fitted with a stop/start battery, although my vehicle does not have stop/start - could this be a problem?
Many thanks in advance.....
Willie
Threads: 75
Thanks Received: 1,302 in 1,140 posts
Thanks Given: 223
163
It's likely to be the alternator / voltage regulator on the alternator. That is too high, should be 14.4v max roughly.
Threads: 13
Thanks Given: 61
4
11 months old battery? Still under warranty?
11-04-2021, 07:45 PM
(11-04-2021, 12:39 PM)Zion Wrote: It's likely to be the alternator / voltage regulator on the alternator. That is too high, should be 14.4v max roughly.
Thanks for the reply, Zion - yes, that's what I was suspecting, was just wondering if the ECU had any influence on the charging settings?
Oh well, time to source a replacement alternator then ![[Image: thumbsup.png]](https://berlingoforum.b-cdn.net/images/icons/thumbsup.png)
Cheers,
Willie
(11-04-2021, 12:40 PM)Pedronicus Wrote: 11 months old battery? Still under warranty?
Possibly, but not if it's been cooked by an over-enthusiastic charging regime, I would assume?
Threads: 75
Thanks Given: 223
163
The ECU doesn't control the charge voltage but there is a smart battery monitor built into the positive terminal. Maybe worth checking the connections are all clean and right.
11-04-2021, 08:40 PM
(11-04-2021, 08:14 PM)Zion Wrote: The ECU doesn't control the charge voltage but there is a smart battery monitor built into the positive terminal. Maybe worth checking the connections are all clean and right.
Good info, thanks - will check that in the morning before I start looking for an alternator.
Threads: 75
Thanks Given: 223
163
12-04-2021, 06:40 AM
(This post was last modified: 12-04-2021, 06:43 AM by Sol.)
And measure the voltage between the inner wing earth cable bolt on the passenger side, and the centre of the Lead battery + post, to be sure the voltage is actually reaching the battery. If it's 15v at the Lead post, then I'd say the alternator is the problem - some garages will have a DC ammeter tester to see what current is being sent to the battery too. High voltages can buckle the plates inside. Not sure if a stop start battery needs a different alternator in the cars which have it, as the battery chemistry may be different.
If it's a lot less at the Lead post, then the connector voltage may be high because the load of the battery is not actually being "seen" by the alternator (bad connection etc)
12-04-2021, 08:48 PM
(12-04-2021, 06:40 AM)Zion Wrote: And measure the voltage between the inner wing earth cable bolt on the passenger side, and the centre of the Lead battery + post, to be sure the voltage is actually reaching the battery. If it's 15v at the Lead post, then I'd say the alternator is the problem - some garages will have a DC ammeter tester to see what current is being sent to the battery too. High voltages can buckle the plates inside. Not sure if a stop start battery needs a different alternator in the cars which have it, as the battery chemistry may be different.
Thanks for that - all checked out OK.
Ordered a new voltage regulator, going to try that first - complete alternator is £230 ![[Image: shocked.png]](https://berlingoforum.b-cdn.net/images/icons/shocked.png)
Thanks for all the replies
M59 1.4 Petrol question
Today 11:37 AM
Cold Starting
Last Post: jboy012000
Yesterday 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
