Programme out EGR without blanking?
Hello all,
I'm aware that if I blank off my EGR on my 1.6HDI without reprogramming the ECU I'll throw up an error code.
I'm thinking of getting my engine remapped soon. Is it possible to run the van with the EGR mechanically in place, but mapped out until I get round to fitting a blanking plate?
Just thinking it might be worth getting all the ECU work done at once, so that it's ready for when I get round to blanking off the EGR in say 6 months time. Or will I cause some sort of damage?
Completely accept that until I've done the work I obviously won't see any benefit. Just saves me getting the ECU programmed twice.
You need to do a bit more reading about blanking the 1.6HDi, there's lots of info out there, or contact HDI Tuning for advice.
Sorry for being vague but it's now illegal to do what you have in mind.
As it happens, although illegal, many remapping firms will electronically delete the egr without a problem.
I am also on a Mercedes forum, and we have a huge thread about egr deletes. I've done it to my Merc, and it involves fooling the ecu into thinking the egr is operating by wiring in a resistor to the egr/maf circuitry.
Hope that helps.
Gravity
The M59 throws no EML on when blanked. Only the B9 onward does.
(16-04-2021, 02:20 PM)Crofty1984 Wrote:  Hello all,
On my 1.6hdi 2008 year I have removed EGR from firmware ECU. 3 years ago. Did not put blanking plate only disconnected wires plug to EGR.
No problems at all. It was professional remove, not the one where only EML light is disabled. That was about 100E . I already have ECU programmer.
It really depends what firmware version is in your ECU. Some firmware allow blanking EGR and not throwing any errors.
You can try to blank EGR and take it for spin. If you don't get errors than you are in luck.
If you get error than you must remove it from firmware ECU.
Best regards,
brajomobil
Best regards,
brajomobil
Is it just has easy to fit a new ERG
Is it just easy to fit a new ERG
Smile
(13-08-2021, 08:49 PM)Bushwacker Wrote:  Is it just easy to fit a new EGR [Image: smile.png]
[-] The following 1 user says Thank You to Bushwacker for this post:
  • uk_friendly_fire
I agree with Bushwhacker get it replaced.
The engine was designed with it in place for a reason.
2021 Berlingo Flair M (K9) 130D
I.T. is there to help, but unforgiving if you make a mistake
https://www.evanshalshaw.com/blog/what-is-an-egr-valve/
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
Today 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
Today 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
Yesterday 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
Barn Doors - Lockign Mechanism HELP?
10-06-2025 07:13 AM
