test eolys pump + electronics
#11
(17-04-2021, 01:24 PM)Dutch Wrote:  Does anyone know how to test the functioning of the eolys pump on a 1.6 hdi?
I removed the whole tank and had a look at the pump and electronics, but couldn't see anything unusual. When I simply connect the two wires that go to the pump to 12V (after removing the electronic circuit board thingy) I only hear a sort of a click, but do not notice any pump action. Could this mean the pump is knackered?? Or does it need a different input than a simple 12V DC
In Diagbox 7.58, in POMPE_MUX_TI computer, there ar 2 tests:
1. Sound test - to just listen if the pump is clicking during some 30 s or so
2. Flow test - disconnect the hose going from the pump to the diesel tank and put under the pump outlet a vessel, a cup to catch it, then run the test and after the end, you should measure ~15 ml (I guess 15, it is written in instructions there). No lifting is needed (at my car).
For me test 1. works, test 2. I measured only 5 ml.
I have Peugeot Partner 1.6 HDi, 68 kW, 2013, Diagbox China, no errors.
Not able to register
Last Post: Mike
Yesterday 11:03 PM
2011 B9 DPF warning light
Yesterday 10:51 PM
Last Post: gitt
Yesterday 10:46 PM
Last Post: Matt Haigh
Yesterday 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
21-01-2025 03:09 PM
Last Post: pondweed
21-01-2025 01:21 PM
21-01-2025 12:41 PM
21-01-2025 09:18 AM
» Replies: 23
Free To Collect From CO14 8LD B9/K9 Floor Mats
21-01-2025 12:43 AM
