Paint job
Hi all, help needed !! the bulge on the bottom of my tailgate ,the laquer coat is bubbleing off !!if i sand it all off and respray it !! will i have to respray a laquer coat ??? because it's plastic thought it might need more attention for painting ?? spraying it matt black also crossed my mind. Thanks in advance !!
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
You can get plastic primers which help the paint to stick - if spraying with a gloss finish (rattle can) then finish with a spray leveller or clear lacquer . If you just pick off the peeling bits - I did on mine, using a power washer - as it's an old 'un - then a clear coat makes it look presentable from a distance and slows down the acne.
Mine is red, and all red ones seem to suffer the same fate!
thanks for responding oilyrag, so i need 1 can of plastic primer ,1 can of gloss finish , and 1 can of clear laquer to do the best job ?? not that I'll do the best job mi nd lol,will 1 can of each be enough do you think ,??
(17-04-2021, 08:11 PM)oilyrag Wrote:  Mine is red, and all red ones seem to suffer the same fate!
Yep, my M49 van is red ("passion red", if I remember correctly), and the lacquer started peeling off the bonnet, roof and (plastic) front grille many years ago. On the bonnet it was precipitated by a pigeon crapping on it after it had eaten blackberries - I should have quickly washed it off.  About 18 months ago I had a bit of welding done where the offside sill meets the side panel, and for an extra £100 the bodyshop resprayed the bonnet completely, which seemed a pretty good deal (assuming it lasts).
(17-04-2021, 05:57 PM)my mucker Wrote:  Hi all, help needed !! the bulge on the bottom of my tailgate ,the laquer coat is bubbleing off !!if i sand it all off and respray it !! will i have to respray a laquer coat ??? because it's plastic thought it might need more attention for painting ?? spraying it matt black also crossed my mind. Thanks in advance !!
Best post up a good clear photo of the area so we can get a better idea of what will be required.
(17-04-2021, 08:35 PM)my mucker Wrote:  thanks for responding oilyrag, so i need 1 can of plastic primer ,1 can of gloss finish , and 1 can of clear laquer to do  the best job ?? not that I'll  do the best job mi nd lol,will 1 can of each be enough do you think ,??
Should be enough - you'll need some masking tape and some thinners to degrease the surface before priming. Good luck! (Give time between various coats and choose a warm, dry day. )
ok, thanks mucker I'll try to upload a photo of it when i finish it !!! if its a bad job ,i wont ,ha ha
ok JJ, ill try to upload a photo,I've had instructions how to do it,but at my age i forget things quite easyily,!!!
[-] The following 1 user says Thank You to my mucker for this post:
  • jj9
ok JJ see i can do this for you !! Hooray !!
Attached Files Thumbnail(s)
  • jj9
Oh yes, I see your problem clearly now.
You could try picking off the flaking clear coat until you get back to an area where it is sound, then using fine wet & dry paper (wet) carefully feather the edges, if you're lucky they may blend in without disturbing the colour coat too much. The problem is that most of the time the clear is flaking off all over the place, or once you start trying to feather the edges of it the flaking continues.
You would more than likely be better off just sanding it all down and dusting a couple of coats of colour over it then a couple of coats of clear coat. The problem you face is that the colour coat may not be a very good match to the original colour, that said sometimes you get lucky and it's very good match.
2015 Berlingo van for sale
Last Post: eddyale
Today 06:47 PM
Last Post: deejay_xb
Today 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
Today 01:48 PM
Unusual Braking Problem
Today 07:52 AM
valeo alternator CL15 rebuild
Today 07:49 AM
Yesterday 06:19 PM
oil Sump
Yesterday 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Yesterday 04:34 PM
M59 1.4 Petrol question
14-03-2025 10:48 PM
14-03-2025 09:08 AM
