Third party BSI repair
Has anyone tried places that do BSI repair?
It seems like BBA-reman went under, but possibly set themselves up again last year.
I just cannot get the two boards apart on mine.
Im sure there was someone on the forum about two weeks ago saying they had their BSI unit repaired, perhaps others can remember who it was or they will come forward.
I fixed my own with an ebay bsi. What are you doing with it Ben ? If you just want it splitting I'm not that far from Sheffield.
Well I'm not 100% certain I can be arsed pulling it out again yet, but it's a central locking issue.
As far as I can tell one of the relays is broken, I managed to get a probe on it and it's an open circuit, so I figured I'd try replacing it.
I'll have another look and be in touch if I get no joy.
Folk have used an old wooden ruler to prise the two sections apart. the connectors are tight.
(24-04-2021, 08:12 AM)benoliver999 Wrote:  Well I'm not 100% certain I can be arsed pulling it out again yet, but it's a central locking issue.
I had a central locking problem a few years ago. The car locked but would not unlock. I took out the BSI, split the 2 boards and replaced the servo board (the one with all the relays) with one from a scrapper. That solved the problem, but later I wondered if it was the connections between the 2 boards that was the problem. Had I reassembled by old servo board it might have worked. So I think it's definitely worth separating the 2 boards and checking the 2 multi pin connections.
Mine didn't work when I bought the 2005 2.0 Multispace in 2012. The previous owner had hardly used it and it had been idle for some time. My car was recently marooned in France from September last year, because I was not allowed to visit. I only managed to retrieve it this September, so it had been again idle for a very long time. And, perhaps significantly, the car again locks OK but will not unlock. I am plucking up courage to take out the BSI and try cleaning up the pins.
I just wondered, reading your post, how you went on. Did you replace any relays? If so which ones? They look like they will need a very hot and beefy soldering iron.
Mike
It was definitely the relays on mine, I tested them with a multimeter, but I have read elsewhere of dodgy connections between the two boards so I think you're wise not to rule it out.
I ended up replacing the board with a donor board - easier in the end than trying to replace the relays. It was an absolute nightmare getting the boards back together.
I saw one repair where the top and bottom boards were soldered together because they were not connecting. Mine was a real pig to get back down to where it was originally I had to lean on it with a piece of wood several times. I took the defective relay of the old board but never replaced it as the second hand top board did the job.
(26-10-2021, 06:14 PM)benoliver999 Wrote:  It was definitely the relays on mine, I tested them with a multimeter, but I have read elsewhere of dodgy connections between the two boards so I think you're wise not to rule it out.
Thanks for the info. I will have a further look at the old servo board I removed last time and test the relays as you have done, with a separate PSU and a multimeter. I think the relays are still available but another trip to the scrappers might be a simpler option.
I will post again when I have a result.
I have now removed the BSI and split the 2 boards. The YH119 Z series relay coil is definitely open circuit. This relay is obviously a weak part of the system. So many people seem to have this problem.
It took me about 2 hours to remove the relay from the board, due in no small way to the fact that the board is laquered. Had to scrape all that off first, then a Weller temperature controlled iron on full belt, and a solder sucker and solder wick eventually got through all the solder. The pins are soldered both sides of the board so it's a difficult job. Patience paid off eventually.
I have ordered 2 relays from CPC. The are not Tyke originals but are the same spec. The reference number is V23076A1001C133, otherwise known as 1393277-4. Cost is £3.30 each  but handling £4.95. Still a lot cheaper than the alternatives. Hope they arrive soon as I need the car next week. Will advise result
[-] The following 2 users say Thank You to mikeB for this post:
  • cancunia, Tomcat3
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
