Calliper bolts
Hi, I know this is a berlingo forum but I'm having troubles with my Dispatch, can anyone link to the bolts that hold the calliper assembly to the stub axle at the rear, I need to change the discs but I cant get the bolts out so will have to grind them off. This is the male torx type bolt and not the slide pins bolt by the way.
Alternatively any ideas on the thread size so I can put hex bolts back in instead, They are a pain in the arse to undo, I've got the correct socket but you cant get a socket in so I've had to use a spanner but the heads are chocolate and just disintegrate, I also think they are threadlocked.
2015 Dispatch 1.6 HDI, Thanks.
In case / before we get in trouble ...
Have a look here
https://www.peugeotforums.com/threads/an...st-2332580
Cheers, I see it says to remove the hub itself to get to the bolts, I thought of that whilst I was trying but you can't get a socket on them either because the spring is in the way, You could possibly get a spanner on them but I'll bet they are tight and my biggest spanner is 19mm. I've put it all back together for now.
Main dealer is best bet
Last Post: Muppets on Mars
Today 10:48 AM
Last Post: JPCoetzee
Yesterday 03:52 PM
OIL Drip
Yesterday 01:49 PM
Yesterday 01:42 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
