Threads: 9
Thanks Received: 6 in 6 posts
Thanks Given: 32
26-04-2021, 05:50 AM
Hi everybody,
Since I've changed my radio unit with another upgraded system, which came with a new display with more informations, now i have the external temperature indicator with "--". Of course i don't have the sensor on the mirror, but I'm wondering if it is possible to install it. The question is :Where i have to check for the connection of the sensor, on the display or somewhere else? Which colours are the wires that I'm looking for? Thanks a lot in advance.
Threads: 75
Thanks Given: 223
164
Black wires, and they should be at the mirror plug on the drivers side already if you can add the sensor.. They go all the way to the BSI, not the radio display. It is only showing the value told to it by the BSI computer.
Threads: 9
Thanks Given: 32
26-04-2021, 06:38 PM
That's great buddies, I'll start to investigate and I'll revert soon
Thanks Received: 13 in 12 posts
Thanks Given: 4
Did you use a adapter for the wiring?
The display functions for some reason do need the old stereo. If you remove it you will need a special wiring harness. Also if you have the steeringwheel controls then the adapter wil make sure the aftermarket stereo is able to use those as well
2007 Peugeot Partner Zenith RIP
2010 Seat Ibiza ST
Threads: 123
Thanks Given: 250
34
Can you post a link to what you found?
Threads: 9
Thanks Given: 32
Thanks a lot for your guide. I gave a quick check to you related post and tomorrow I'm going to try. Thanks again, and if you need any further information about the stereo feel free to contact me. I also put an amplifier plug and play from amazon, with a passive subwoofer in the trunk and it sounds really amazing. I can also provide pictures if needed. Cheers ? all
