Side impact sensor - permanent fault.
Hi ?
My berlingo failed inspection due to an airbag light being illuminated.
Both the seat airbag and seatbelt pretensioner wires has been soldered instead of using the plugs.
I had Pp2000 read out the airbag module, and it has a permanent fault on left side colission/impact/crash sensor.
Tried 3 sensors now, on the location i know of on the left side (under left door), checking plugs and wires, wich looks perfect.
I went to check the airbag module in the car, and the 3 ground connections were corroded, so i cleaned them up, fault is still there.
Im lost for what Else it could be.
Any advice or ideas?
If the car had an accident and the airbags were deployed then the airbag module needs to be changed with a new one and coded to the car.
If you like gaming visit GameForest
(29-04-2021, 09:42 AM)deejay_xb Wrote:  If the car had an accident and the airbags were deployed then the airbag module needs to be changed with a new one and coded to the car.
Hey.
No accidents, nor Any crash data stored in the module, checked because i had the same idea.
Thanks though  Smile
Did you buy the car after its previous MOT?
Are you sure about its crash history?
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
(29-04-2021, 10:25 AM)Rasputin Wrote:  Did you buy the car after its previous MOT?
(Here in denmark MOT is every 2 years, so i have had the vehicle for 3 years now)
I bought it a year before previous MOT, and have been driving for nearly 2 years with no airbag light on.
I havent been in any crashes, and diagbox/pp2000 says no crash data stored.
So im not fully sure that it havent had any crashes since '03, but the airbag system have been working.
about 18 months ago, it had an intermittent  error on the same sensor that now has permanent error, that got fixed by replacing the sensor.
The joints being soldered instead of plugs suggests that the fault existed before, and someone though the problem was with the plugs. It clearly is not though.
You seem to have fixed the problem by replacing the sensor, but not for long. That suggests that the sensor is not the issue either - when you replaced it you were just lucky that the real fault, wherever it is, was corrected for a while. So you were led to believe that the old sensor was faulty, but it wasn't.
I have to guess now, but could the fault be with the signal telling the BSI that the airbag is okay or not? Could there be an intermittent connection somewhere along its route?
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
(29-04-2021, 11:25 AM)Rasputin Wrote:  The joints being soldered instead of plugs suggests that the fault existed before, and someone though the problem was with the plugs. It clearly is not though.
The sensor is a seperate loom from the seat thats been soldered though. but i think your right in saying that the sensor is not the issue Smile m thinking the issue might be in the loom to the sensor somewhere? But how would i meassure that? The fault went away after fiddling with the sensor yesterday, only to come back as the same permanent fault today.
It could very well be the BSI, but would the fault not be intermittent instead then?
It depends on ease of access and no doubt other things, but the theory is to check for continuity along the relevant wire in the loom by touching each end with probes from a multimeter when everything in the car is powered down (for safety). You'd obvioulsy need an extension wire for one of the probes, and someone on here may have wiring diags with wire codes.
The trouble with "intermittent" is that it can be as fast as a flashing light or so slow that it seems not to be intermittent, taking even as much as weeks to flip or flop over. I suppose there could be a problem within the BSI (poor connection or link etc) but it could also be before the BSI, in whatever route it gets its airbag data from.
I am only able to offer a bit of logical thinking, wish I had more hands-on experience.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
[-] The following 1 user says Thank You to Gryffindor for this post:
  • Kombo
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
