DAB radio
Hi,
Has anyone used one of these DAB converter things that you can plug into your cigarette lighter? Are they any good or is there a better way to have DAB without changing the radio?
My brother uses a "Pure DAB 300 Highway" which works just fine. There are many others out there, many cheaper. Be aware though that they come with a DAB aerial that has be stuck inside the windscreen, the unit needs power from cigarette lighter/power socket and the input to the existing radio is by connection into the aux socket or aerial socket.
To do a semi-tidy installation requires running the DAB aerial lead down inside the A-pillar trim, and you've got to tidily route the power and aux cables to wherever you choose to mount the unit.
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
I bought one of these and it works well.
[Image: 8841e8e701b49b86caffcb7ca0971f22.jpg]
Yes use a Kenwood DAB adapter works perfectly.
2001 1.9D Multispace.
Rear door filling with water
Yesterday 06:56 PM
MOT Emissions repeated fail
Yesterday 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
