Lost with Cruise control
Threads: 9
Thanks Received: 6 in 6 posts
Thanks Given: 32
Hi everybody,
After reading almost all the treads about CC i finally... get lost!
My situation : Berlingo 1.6 HDi '07, o
genuine command with only cruise without speed limiter, activated in BSI and tested working trying the impulses through the lever (speed up, speed down and pause). On the road no response, neither in 4th gear over 50 km/h and 5th gear. I also tried with new cockpit, the one with the display for CC activation, following the parts number as per the thousands of tread found on the web. The cockpit doesn't work at all, all the lights are flashing and no indicators. When i clear the errors shown on Diagbox, it work for a secon and i can also see the mileage, but then, flash again. Should I give up? Thanks in advance for your help and suggestions.
Threads: 44
Thanks Given: 97
28
06-05-2021, 08:46 PM
(This post was last modified: 06-05-2021, 08:57 PM by Gryffindor.)
Answer to last question first - NO don't give up!
Two thoughts come to mind,
1 do you have all the parts needed (see below)?
2 more urgently, it sounds like your BSI has got messed up.
I can't help with 2 but I am sure others will be able to guide you through the steps. This is what needs resolving first I think.
While you work on that problem, you can make a double check of no.1:
There are a few parts your car must have for CC to work, as listed in earlier threads. Have you checked fully that you have them all?
- Brake pedal switch
- Clutch pedal switch
- Cable operated gas pedal*
- Original used CC stalk from a breaker, NOT one of the new clones, which do not work.
*As explained in other threads, your gas pedal must operate a cable (a bit like a bicycle brake cable) which goes through your firewall into the engine bay, if CC is to work. If instead it has four electric wires going through the firewall, CC will not be possible.
This problem you are having could be an issue with your "cockpit" - I think you mean what is called a cluster or instrument cluster here? I do have one with CC display as well but have not got round to fitting it (or CC) yet, so I have no direct experience to help. Hopefully others who do have experience can advise.
It is of course possible that you have bought a faulty cluster? One other forum member has recently got CC working with only the standard cluster. The CC works, but there is no display of what speed it is set to. He is happy with that. So maybe you can refit your original standard cluster, just to see if the new one is the problem. If you are lucky, CC will work with the old cluster. Or it will after the BSI has been fixed.
Once the BSI is fixed, first try resetting the car back to having no CC, as it was before you started. Now try reinstalling the new cluster but make no other changes. In theory, it should work okay except of course that there is no CC active. If that goes well, then your new cluster is good and you can start with the CC installation again.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Threads: 61
Thanks Given: 234
29
Did not quite understand if you changed your instrument cluster with the one with the small square CC LCD display. If you had done so, the BSI needs to be updated to instrument cluster with CC type 2. All is in this thread: https://www.berlingoforum.com/thread-16110.html
Instrument cluster display type 1 (NO CC LCD) and if this is switched to 2 in Diagbox/LExia/PP2000 you will get Christmas lights
Instrument cluster display type 2 (WITH CC LCD) and if this is switched to 1 in Diagbox/LExia/PP2000 you will get Christmas lights
The CC (1.6HDi M59) will only work with the instrument cluster with CC LCD. It will work without it, but the instrument cluster will not work. Check the thread, it is explained.
The following 1 user says Thank You to saskak for this post:1 user says Thank You to saskak for this post
• Metamatix
Threads: 9
Thanks Given: 32
Thanks for yours reply.
Actually i put again the original instrument, the one without the lcd,since the type 2 was flashing and not working. I've read the tread that you post me, but the problem is that i cannot see the option "cluster type 2"in lexia.
I've followed the instructions posted but i cannot find this" menu".
The lever is a genuine Citroen part, with code OE 6242Z9.
The cockpit is a genuine Citroen part, from a Berlingo same engine and year, but with CC lcd cluster,
part no. 9662744380
The function is activated in BSI and respond at the test, but is not working on driving.
I will better check for pedals.
Now, in order to "clean" the messed up BSI should i perform a reset of it? Can you please suggest the procedure to do it? Thank for your helpful support, a lot!
Threads: 61
Thanks Given: 234
29
06-05-2021, 10:28 PM
(This post was last modified: 06-05-2021, 10:30 PM by saskak.)
(06-05-2021, 09:33 PM)Metamatix Wrote: Thanks for yours reply.
part no. 9662744380
My car is a Pug Partner, same as Berlingo, just a badge difference. So, I cannot quite confirm the sequence in Lexia as I cannot run it, but I think someone in the thread showed the correct menus for Citroen to change it to type 2. There is no need to reset BSI, etc., just the correct configuration for the instrument cluster. Do this with the Instrument cluster with the CC LCD, not the original (old) one.
From Brajomobil from the thread:
In Diagbox/Lexia in ECU -> configuration -> Manual configuration->
Presence of cruise control:Yes -> Configure -> use code 03114
In Diagbox/Lexia in BSI -> configuration -> Manual configuration->
Presence and type of cruise control: Cruise control and speed limitation
Threads: 44
Thanks Given: 97
28
(06-05-2021, 10:28 PM)saskak Wrote: In Diagbox/Lexia in BSI -> configuration -> Manual configuration->
Thanks for stepping in, saskak. The only point I note is that Metamatix does not have speed limiter.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
Threads: 61
Thanks Given: 234
29
(07-05-2021, 07:11 AM)Rasputin Wrote: (06-05-2021, 10:28 PM)saskak Wrote: In Diagbox/Lexia in BSI -> configuration -> Manual configuration->
I think, but cannot quite remember, the option for cruise in the BSI is cruise and speed limitation, there is not just cruise control only. I think it is a bad translation from French.
• Metamatix
Threads: 123
Thanks Given: 250
34
I installed CC on my Berlingo M59 1.6HDi using the LCD instrument panel & Lexia. I think Brajomobil did the same. It is correct that you need to choose 'type 2'.
I see the BSI config is mentioned, but did you also change the 'Injection ECU'?
Threads: 9
Thanks Given: 32
Hello dear buddies,
i thank you really so much for your support, but I'm stuck in the same situation. Mainly i can see that in my diagbox some sub-menu does not exists, as for example the possibility to choose between instrument type I and type II,so my cockpit still flashing Stop sign and fuel with all lights on. Anyhow, my last chance is to go at a Citroën workshop to see what can be done.
If someone has new tips to suggest, I'm here waiting.
Thanks again a lot a lot a lot.
Threads: 123
Thanks Given: 250
34
Have you tried with Lexia, not Diagbox?
