[WTB] Drivers side front door seal
Hi. I'm after the seal that is on the front drivers door aperture, it's for a 2010 Berlingo B9 multispace. It's the one that go's along the door sill up the A post across the top meeting up with the roof lining then down the B post meeting up with the sill again. If anyone has one for sale or can point me in the right direction I would be grateful. I have checked breakers yards in the Manchester area with no luck. Best wishes Dave.  Smile
My Car :- 2010 Citroen Berlingo XTR Multispace
I need to get one of these for my M49 - the seal's come away at the top and water is getting inside.  I've looked at a couple on ebay but they're pre-used and can't really tell if they'll be any better than the one that needs replacing. The same would be the case for breaker's yard examples. I think I might try my local citroen specialist garage.
Try an internet search , I found door seal stuff for my old berlingo that was about £5,00 a mtr.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
I know this request was a while back now but just for info, the drivers side door seals are always the first to go for the obvious reason of the most use. The thing that people tend to forget, is that the front passenger side has the same size seal and is normally a lot less worn...
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
