Fitting longitudinal roof rails to an XL
I am looking at a 2019 flair XL. It doesn’t have longitudinal roof rails. The Citrien garage is saying it will cost £1500 to supply and fit. That seems steep. Does anyone know how easy it is to fit these rails?
These seem to be the right parts https://tradevanaccessories.co.uk/citroe...lwb-black/
Are they? And are they easy to fit?
The advert says "Easy mounting System NO DRILL fixings included in pack"
So I guess there are fixing points on the car.
A wee bit cheaper than the Citroen quote!!!!!!!!!
Geoff
Make sure to get the crossbars as well. No other vendor has K9-compatible flush bars.
ex: 2003 1.4i cargo
Are you sure the Citroen garage have quoted you correctly?  On my new K9 van the dealer supplied and fitted an 'ulti' Rhino roof rack for £355. It's not a base spec rack (it has a rear roller) and looks like it should be dearer than those rails.
(10-05-2021, 08:59 PM)boop Wrote:  Make sure to get the crossbars as well. No other vendor has K9-compatible flush bars.
The load rating on those roof bars is not very high. Better to invest in a proper rack if you want to carry anything substantial.
Isn't 75 kg the industry standard for a roof rack?
ex: 2003 1.4i cargo
I think the max load on the rack on my M49 is 100kg, though this doesn't mean things will definitely break if you load it more than that - I once loaded 8 (or maybe 10?) 8ft fence posts on it, which would have been around 130-150kg or maybe more, to no ill effect. Though I wouldn't recommend it. (I only did it cos I remembered about the max load after I'd bought the posts). My guess is that if someone starts piling really heavy loads on, it'll be the vehicle roof/pillars that start to deform before the rack does....
The pillars are fine. They are part of the roll cage designed to withstand a rollover without collapsing. The 75 kg limit was the industry agreement to prevent people from raising the center of gravity enough ta cause vehicle instability. For example a Rhino style platform will sleep two or carry big loads safely without damaging the structure in any way.
ex: 2003 1.4i cargo
Engine Fan Running
Today 08:42 AM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
