[Warning Light] alternator
Thanks Given: 3
Hi, I have a 2007 multi space 1.6hdi , I am having battery problems on frosty mornings but not when it is warmer weather, the battery discharges and the battery light is on, after recharging the battery the light goes out but comes back on for a few seconds then is usually ok all day, the next day it is low again, the battery warning light will some times come on and the battery will discharge when driving , but the problem is not on all the time, any help would be appreciated, cheers
Threads: 61
Thanks Given: 234
29
(12-05-2021, 02:58 PM)efespilsen Wrote: Hi, I have a 2007 multi space 1.6hdi , I am having battery problems on frosty mornings but not when it is warmer weather, the battery discharges and the battery light is on, after recharging the battery the light goes out but comes back on for a few seconds then is usually ok all day, the next day it is low again, the battery warning light will some times come on and the battery will discharge when driving , but the problem is not on all the time, any help would be appreciated, cheers
You might have some parasitic current draw from somewhere and it is discharging the battery when switched off ofor example. You can easily check with a multimeter to see where exactly it is coming from. I only had a quick search and here is a video of how to do it: https://www.youtube.com/watch?v=KF1gijj03_0
Might not be the best one out there, but you will get the gist of it.
Of course with the multimeter you can also check if the alternator is producing enough current/voltage to charge the battery, as it may be due to the alternator rather than parasitic voltage draw.
The following 1 user says Thank You to saskak for this post:1 user says Thank You to saskak for this post
• efespilsen
Threads: 3
Thanks Received: 2 in 2 posts
You will probably end up changing both the battery and the alternator if it is sometimes discharging when driving. If it is discharging overnight when cold that is normally a bad battery.
The following 1 user says Thank You to RobS for this post:1 user says Thank You to RobS for this post
• efespilsen
Thanks Given: 3
Hi, thanks for the tips, i have replaced the battery and very little difference, put a tester onto the battery and alternator and it said both were ok, that's why i thought you guys might have come across this before or something like, cheers
Thanks Given: 3
Threads: 75
Thanks Received: 1,310 in 1,140 posts
Thanks Given: 223
164
Does it have an aftermarket stereo? Some folk have found certain stereos not powering down properly and draining the battery.
What voltage do you get at the battery terminals when it's running? Should be around 14.4v and no less than 11v while cranking.
Thanks Given: 3
(12-05-2021, 07:04 PM)Zion Wrote: Does it have an aftermarket stereo? Some folk have found certain stereos not powering down properly and draining the battery.
yep but i had it in my last berlingo for 8+ years and no problems
Thanks Given: 3
and i always turn it off manually
Threads: 17
Thanks Received: 13 in 10 posts
Thanks Given: 16
4
Also worth checking the belt I guess
Threads: 75
Thanks Given: 223
164
12-05-2021, 08:21 PM
(This post was last modified: 12-05-2021, 08:24 PM by Sol.)
(12-05-2021, 07:26 PM)efespilsen Wrote: yep but i had it in my last berlingo for 8+ years and no problems
None of that means it's not draining the battery down now......try disconnecting it for a few days and see if the problem goes away.
• efespilsen
Last Post: JPCoetzee
Today 03:52 PM
OIL Drip
Today 01:49 PM
Today 01:42 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
