berlingo ignition keypad
Hi all. Ive recently taken on the job of bringing a 1998 citroen berlingo up to mot standard. it has  the 1902 cc engine  and came without keys. ive managed to start the van by fitting a stop solenoid to the fuel pump ive not been able to completely bypass the keypad unit which originally required a 4 digit code to start the vehicle. By randomly joining different wires which have all been taken out of the ignition lock i have what appears to be the ignition circuit active, ie indicators, wipers, washers and heater working  but with the engine switched off there are no ignition lights when the relevant wires are crossed and also the fuel and temp guages dont work. i still have a red light blinking on the keypad module and from memory i think this should be green when the correct code was entered. any advice on how to bypass this module would be appreciated.
I saw something on the internet some time ago about bypassing that key pad so do some searching it was in French.
Last Post: Triggermann
Today 01:47 PM
Today 12:50 PM
Yesterday 12:17 PM
Last Post: wbchevron
Yesterday 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
