M59 Berlingo Van Front Seats
Want to change the (now collapsed) fronts on my van. Any after-market seats will do(must have up-down adjust and bolt on to existing floor-pan mounts and be based around Recarro style..ish). Its a minefield out there so any advice on options appreciated.
Ooo.. and can I put slightly wider tyres on my standard 14" steels(bit better grip around corners and squatter stance).
Ta for help..
Why not fit a set of 15inch alloys. I fitted a Peugeot 307 alloys on our M49. I had to reduce from the 307 tyre width to 175/65/15, buy a set of longer wheel bolts off ebay and fit 5mm spacers on the rears to get the clearance. They've been on years with no problem. Just easy to damage on kerb as tyres don't protect wheel edge being slightly narrower. Sorry can't help with seats M49 and M59 have different seat runner mountings
I just picked up a pair of front seats from a 207cc. Will let you know whats involved once i get them in.
(16-05-2021, 05:21 PM)Hoopdub Wrote:  I just picked up a pair of front seats from a 207cc. Will let you know whats  involved once i get them in.
I was looking at that option. The bolsters on mine are wearing now and the cushion has sunk so Im nearly on the floorpan. Just need to tart it up a bit. As far as I can see its 4 allen screws out and disconnect the multi-plug.
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
