how to replace sliding doors
Hello
I will be replacing both of sliding doors in my Multispace 2010.
I bought used doors already. ( the same colour)
I have to install windows and inside upholstery from old one to new doors.
I bought new plastic clips to inside panel ( is case of damage during removal).
Can I use the same fastening system of windows or I have to buy also new one because it usually breaks down?
Where is the electric plug to disconnect  door cable? Under the rear seat?
Is there any instruction/ manual how to dismantle sliding doors in B9?
I see subjects only for older model.
Thanks in advance
Adam
(19-05-2021, 01:11 PM)grajek Wrote:  Hello
Thanks in advance
Adam
Hello, welcome to the forum.
Please see attached files, hope they help.
.pdf   B9 Sliding Door Removal.pdf (Size: 369.25 KB / Downloads: 26)
.pdf   B9 Sliding Door Window.pdf (Size: 207.36 KB / Downloads: 16)
Thank you Cancunia.
I will start this job on Friday.
If I will take some pictures, I will share here with others.
(19-05-2021, 06:42 PM)grajek Wrote:  Thank you Cancunia.
You are welcome.
Pictures will help others, please post them.
It's not a difficult job, just be careful when locating the new door runners. It's easier with two people as the middle runner tries to spring out of the rail. All of the clips will break when you try and remove them, almost guaranteed.
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
26-02-2026 07:20 PM
