25-05-2021, 08:57 AM
Hello all, hope someone can give me a knowledgeable opinion.
My engine light has come on, I've looked for a fault code but the can only find the following using icarsoft V1 tool;
Fuel high pressure circuit - Fuel pressure lower than reference value
Temp fault - DenOx system circuit, leak detected
Temp fault - Pre-cat converter
The car is starting and running perfectly, I'm going to change the fuel filter to start with, how does the system bled, I can't see any priming pump on top of
the filter housing or elsewhere.
The light went off for a bit but came back on after driving for a while, is it worth doing a BSI reset after changing the filter as well?
Thanks...
Thanks...
