Threads: 11
Thanks Received: 1 in 1 posts
Thanks Given: 12
Due to my 5 year old daughter swinging out of it, the lid has come off one of the overhead lockers above the rear seats. The plastic hinges have snapped.
Anyone had this happen before?
Are replacements readily available from Citroen?
Looks like I'll have to drop the whole Modutop down from the roof the get at the hinges.
Threads: 41
Thanks Given: 82
6
The following 1 user says Thank You to Mike for this post:1 user says Thank You to Mike for this post
• eyelight
Threads: 11
Thanks Given: 12
Thanks for that.
The replacement price is crazy.
May try gluing the hinges.
Will have a look at it again next weekend if the weather is any way warm.
Threads: 50
Thanks Given: 743
Glue doesn't work, unfortunately. Just too much stress on the hinges.
Until you can find a couple at a scrappie or on eBay, Velcro will do the trick. :thumbsup:
Threads: 2
Thanks Received: 3 in 2 posts
Thanks Given: 3
18-07-2016, 05:30 PM
(This post was last modified: 10-09-2016, 10:50 AM by waggoner.)
Velcro will work ok until there's a heatwave & the adhesive on it melts & comes unstuck !
Clear cable ties pushed through the slight gap above the door, & then worked round the
broken hinge & pulled up ( but not too tight ! ) will do the trick, without the hassle of having
to remove the doors, the catch will work normally, the repair is hardly noticeable & the job will
take only a few minutes to carry out !
