Tyres - 195-15 or 205-15 for 1.6 Bluehdi 100
As both sizes are specced for the car and both come up as options against my reg on tyre sellers, I wondered if anyone here was using 195 65 15 instead of the usual 205 65 15's?
There's at least £20 - £30 difference between the two for the same brand, so is there any compelling reason to stick with the 205's?
I know that the rolling diameter is marginally lower on the 195's, but don't see that as an issue.
Cheers
And the answer?
Yes it can be done with no issues.
The only consideration is the load rating, as 195's have a very slightly lower rating unless you go for the XL tyres.
So new tyres are Toyo Proxes CF2 95H XL at a saving of over £30 per tyre.
Thanks for update. 195 or 205 is difference in the tyre width not rolling diameter.
(01-10-2021, 08:08 PM)Kieron G Wrote:  Thanks for update. 195 or 205 is difference in the tyre width not rolling diameter.
The 65 is a percentage of the tyre width,  so the 195 does have a slightly (2%) smaller rolling diameter.
https://tire-calc.com/comparison/205-65-...95-65-r15/
https://www.tacomaworld.com/tirecalc?tir...-195-65r15
[-] The following 1 user says Thank You to Harrythephot for this post:
  • Kieron G
Thanks for that. I thought the 65 was just a measurement. Learn something new everyday
Rear door filling with water
Yesterday 06:56 PM
MOT Emissions repeated fail
Yesterday 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
