Threads: 2
Thanks Given: 1
Has anyone encountered this before?
I have 2013 1.6hdi Berlingo which developed a diesel leak from a fuel filter drain pipe
On removing the fuel filter it looks like the green o ring on the end of the housing spigot has been damaged, letting fuel pass.
I've scoured the internet but cant find a replacement, it's and odd size, about 6mm o/d 2mm i/d
None of the standard o ring sets fit, they are too thin, I've looked at air con o rings but dont seem to go that small
Citreon want £130 for a new housing assembly!
Can any one help?
Threads: 123
Thanks Given: 250
34
Welcome to the forum.
If you have a look on catcar.info you should be able to find the part number you need & then search for that online. Also, post a picture of the part in the B9 section of the forum in case anyone else has an idea of what & where to get it?
Threads: 2
Thanks Given: 1
Thank you for a speedy reply, welcome and recomendations.
I have tried your suggestion of catcar.info but it came back with the same diagram as the Citroen dealer which shows the correct assembly but the spigot detail and o ring are not shown separately, not sure how to share the diagram in the post.
I will try the Berlingo B9 section
Many thanks
Threads: 25
Thanks Received: 27 in 26 posts
Thanks Given: 16
6
Maybe worth trying an industrial supplier, such as:
https://www.cromwell.co.uk/
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Threads: 48
Thanks Given: 4
20
I think I've bought seals from that supplier once. Shipped quickly.
Threads: 43
Thanks Received: 414 in 371 posts
Thanks Given: 137
33
Look at the last post by GEOFF and the ebay link . The title gives the sizes
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
