Threads: 2
Thanks Given: 3
Hello
I dont have an original dipstick and this one is bent
Could some one please tell me the good lenght of the dipstick.
Thanks.
Thanks Given: 39
11
You can get one off ebay for around £10. Length will depend on engine type. Even 1.9 diesel dw8 has different lengths for different applications so I would double check with seller with registration or maybe in your case vin number
Threads: 2
Thanks Given: 3
Thanks for the reactuon.
Yeah i want to order one, but they all have different lengths.
My model is 96 with 1100cc dont know if thats enough info?
Threads: 48
Thanks Given: 4
20
1100?
I thought that was just a myth, something we scared small children with?
You may have one of the oldest cars here.
Just a few years until veteran status...
Thanks Given: 188
23
Isnt that the same block as the 1360 petrol, if so the dipstick length from tip to underside of the yellow handle is 495mm on mine. And it is 40mm from the tip to the full mark.
Are we there yet?????
• Hansworst
Thanks Given: 39
11
Out of interest what's 1100cc like to drive in the Berlingo ? Like the electric and 4x4 I've seen the option when ordering parts but never come across one. I guess it's flat in the Netherlands so lower power output is fine to get about. I guess is quite a rare car / van.
Threads: 48
Thanks Given: 4
20
110Km/h (68mph) is just about as fast as I dare drive my 1.4i, too. not because it doesn't have the power(75 lean, mean... lasagnas? Findus! Stop messing with my car!) but because even a light gust of wind from the side can be felt quite noticably.
Please note that the bore and stroke of the 1.1 is different from the 1.4i, so there may be other differences also.
Is it an aluminium body?
(1.4 is cast recycled coke cans, 1.6 is cast rust)
