04-06-2021, 03:57 PM
i have a ghost problem with my 2012 partner, i belive it is a problem with the BSI, i have a 05ff
(unexpected re-initialisation fault coming from the BSI).
But it is manifestic itself in troubles with the manual-automatic gearbox, when i drive the car for shorter trips, it is behaving perfectly, but as soon as i have driven it for a while 45min-60min and sometimes over, the servicelamp "gearbox fault repair needed" shows up.
the car goes in limp mode or something, the sign for automatic goes away, and it goes i manuall. If i go to 3.d gear it will not shift to 4.th
One time this happened i turned of the car and switched back and forth from manuall to automatic, and then the foult suddenly dissapared... (this may have been a coinsidence).
Any idea to where i could look for the foult? i have ordered the lexia-thingy![[Image: 1f609.png]](https://static.xx.fbcdn.net/images/emoji.php/v9/tb0/1.5/16/1f609.png)
Iknow it sounds weird, but i used the sigarette lighter output to charge a phone one time this happened...
I did read a thread somewere were there was some similar problem, but i can not find it again, neither were there a conclusibe answer i belive.
Any tech-heads with ideas of what the issue could be?
