Threads: 123
Thanks Given: 250
34
I've been watching a You Tube video about changing the clutch on a 2.0HDi and it looks like a faff but quite do-able. One question that I have is how best to disconnect the gear change cable links. The video I saw showed the ball joints at the end of the cables being popped off at the selector with some kind of fork tool and the official Service Box method shows a special tool fork tool to do this. Has anyone used a DIY tool, what did you use?
Threads: 5
Thanks Given: 4
21
Take a guess that a (scrapper) open-ended spanner, possibly ground down into a wedge, would pop them off?
The following 1 user says Thank You to oilyrag for this post:1 user says Thank You to oilyrag for this post
• cancunia
Thanks Given: 39
13
I've done a few of these now on M49. I popped the joints off with a heavy duty screw driver used like a pry bar to lever them off. The only HDI I've changed was on a Dispatch which was harder than M49 as I couldn't get gearbox out (without dropping subframe) so had to work in the small space I could create between engine and gearbox
The following 1 user says Thank You to Kieron G for this post:1 user says Thank You to Kieron G for this post
• cancunia
Threads: 3
Thanks Received: 1 in 1 posts
Thanks Given: 1
(10-06-2021, 08:53 AM)cancunia Wrote: I think I'm now a bit more comfortable with getting the selector cable joints off, thanks again for the replies, I'll also check the weather forecast!
The thing that concerns me most is putting the driveshafts back and not damaging the oil seals.
I've just done one. Popped off selector 2 ball boints with a pry bar and undid the black plate holding the fixed one to the the box (with 2x 11mm headed nuts). Just make sure that the fixed ball on the subframe is engaged with the selector lever coming from the gearstick before bolting the fixed ball joint plate back on.
Drive shafts are easy to replace. If they seem solid but not fully home/ engaged turn the shaft a tad as its prob the splines are not lined up.
Worst part of job IMHO is fannying about with the clutch cable getting the bite point "off the floor"..
2010 VTR in Wicked 'Postman Pat' Red.
The following 1 user says Thank You to StueyT for this post:1 user says Thank You to StueyT for this post
• cancunia
