Threads: 4
Thanks Received: 2 in 2 posts
Thanks Given: 2
12-06-2021, 06:25 PM
Does anyone know if you can get ahold of a good fitting boot liner? Mine is crumbling to pieces after 20 years... It'l need to fit the 5-seat multispace, and cover the whole boot when the back seats are pulled forwards, preferably with cutout holes for the seat hooks. I hope someone knows
99' Berlingo Multispace
265.000 km
Threads: 6
Thanks Received: 28 in 24 posts
Thanks Given: 9
I've not seen an aftermarket one, I presume it's the same as the M59 but don't know.
It's a shame you're not in the UK as there must be hundreds of used ones where people have removed them to put ply flooring down.
I was surprised by the weight of mine and thought I might leave it out but left it in place.
I would see if I could cut a new one from rubber flooring using the old as a template.
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
I found a sheet of high density polystyrene blowing about outside which must have fallen off a lorry (actually not an excuse for the judge) and I cut it to fit the boot with a sharp knife. There's another piece of thin rubber sheet which came from a supermarket over the top of it to stop stuff sliding about.
Threads: 17
Thanks Received: 13 in 10 posts
Thanks Given: 16
4
Mine is crumbling on my M59, I have looked around but had no luck yet. OEM price is mad.
One thing I will say, I think what is crumbling might also include some sound deadening underneath the liner. It might be worth bearing that in mind when trying to get a replacement.
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
Just bought some rubber matting for mine off ebay for exactly the same reason. Going to use the old one as a template.
Malcolm
2001 1.9D Multispace.
