stop/start failure.
Sad
The stop/start system on my B9 2012 has failed.  Does anyone have any info on replacing these, as there's nothing in the Haynes?  It's a 1.6 e-HDi.
It's causing an occaisional engine failure light Sad , which Citroen tell me is because the module and capacitor/condenser need replacing.  They want £1200, which seems a bit steep.
I'm sure I've read on here before that there's a UK-based specialist in Berlingo engine parts, but I can't find anything through searching.
Thanks!
My 2014 Airdream 90 (42K) has the same problem. Runs fine, except the stop/start doesn't activate. The ECO light flickers for a second, then goes out. It's not been accidentally switched off, and it doesn't work even when all accessories like wireless, aircon, fan, wipers and lights are off (except DRLs). I seem to have read on this forum that it might need a new battery but it does everything perfectly except the stop / start. Admittedly its only done 400 miles in the last 16 months, but it starts from cold OK.
I think there's a special / very good start/stop battery that's been recommended on here but I can't find it. (Not good at computers / cars).
The stop/start systems require the correct battery to work properly and one that is holding a very good charge or else the system will shut down. The batteries for this type of system are not cheap and its no good cutting corners as its a false economy. You dont say what citroen have said is wrong with the system or what faults have been stored on the car. I may be worth getting a second opinion from a citroen specialist, where are you in the country other members may be able recommend an independent near you.
(14-06-2021, 06:04 PM)Tomcat3 Wrote:  The stop/start systems require the correct battery to work properly and one that is holding a very good charge or else the system will shut down. The batteries for this type of system are not cheap and its no good cutting corners as its a false economy. You dont say what citroen have said is wrong with the system or what faults have been stored on the car. I may be worth getting a second opinion from a citroen specialist, where are you in the country other members may be able recommend an independent near you.
Thanks for your reply.  It's the start/stop module and capacitor/condenser which they say needs replacing.
I'm in the Bath/Bristol area.
(14-06-2021, 05:45 PM)rnamman Wrote:  My 2014 Airdream 90 (42K) has the same problem. Runs fine, except the stop/start doesn't activate. The ECO light flickers for a second, then goes out. It's not been accidentally switched off, and it doesn't work even when all accessories like wireless, aircon, fan, wipers and lights are off (except DRLs). I seem to have read on this forum that it might need a new battery but it does everything perfectly except the stop / start. Admittedly its only done 400 miles in the last 16 months, but it starts from cold OK.
Thanks for the reply.   Smile   It'd be a shame if it were the battery, as it was just replaced last year!  Citroen reckon it's the entire start/stop module and capacitor which needs replacing.
I don't get the same symptoms you're getting.  Start/stop just doesn't work any more, and instead I sometimes get an engine warning light.
(15-06-2021, 11:01 AM)Hi im having the same problem as you describe. Did you manage to rectify the problem?And if so how did you do it? Thanks in advance and kind regards, Paul basswizard Wrote:
Yet another ABS fault
Yesterday 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
