18-06-2021, 07:56 PM
'Hello all,
I recently had the joy of changing my fan belt. Well, all done and the car started up fine after.
But....
A few days later i went to use the car and it turned over with no hint of firing up, well maybe a hint but nothing more. (It is a diesel).
So after a steady dose of key on and hoping.......nothing but a flat battery.
Next, car alongside, jump leads on and more of the same.....nothing.
I was a little stumped, as the car had started after i worked on it with no issues and the only difference from normal use was that it had sat for a while while i was waiting for the belt and then putting the belt on.
So, i stood staring at the engine after removing the plastic shroud that sits on top. I saw some oil staining and thought perhaps a seal is not so good and the fuel is leaking out creating an air gap?
Ten presses on the diesel button (what ever it is called ! ) and i felt it go stiff and i saw fuel fill in the line.
Engine fired up straight off. Brilliant. So, a simple fix for the problem i will just have to find now where the slow leak is. Another day another job.
Photo is of under the cover and the button i pushed.
Take care all..
But....
Take care all..
It's a 2001 1.9d with 322,500 k on the clock.
