rumble noise/vibration
Sad
anyone help please, have a 2007 berlingo 1.6hdi, it has this rather annoying vibration when in lower gears or going from 3 to 4th at low revs, its not gearbox related its more of a vibration noise, not knocking like a worn antiroll bar bush etc, its recently just had outer tie rod ends changed on the steering rack and rear axle bushes changed as worn, the van will drive lovely anywhere but its really hard to explain, just after some advice as its booked in again to a garage to be checked over, the last garage did not find any engine mounts or suspension mounts worn or loose, its like a sound/rattle like something is loose somewhere!
Have a look at the aluminium heat shields around the turbo. With age the aluminium becomes brittle and tend to break from their mounting points and vibrate a lot. It is a 3-piece set, front, upper and at the back of the exhaust. Move them with hand and see if they move.
Air filter box also becomes loose, but I doubt you will be able to hear that from inside the cabin.
(23-06-2021, 08:49 AM)saskak Wrote:  Have a look at the aluminium heat shields around the turbo. With age the aluminium becomes brittle and tend to break from their mounting points and vibrate a lot. It is a 3-piece set, front, upper and at the back of the exhaust. Move them with hand and see if they move.
Hi.
Thanks for your reply, checked heatshield and not that, its more noticable than that only going over uneven or rough ground or road, checked front brake calipers and slight play but all bolts tight, its as though something is not tight enough or loose.
driving me mad as unable to find it at the moment! air filter and top plastics are also ok.
check exhaust, specialy the part between the engine and the first pipe
If you like gaming visit GameForest
(23-06-2021, 05:52 AM)stu76 Wrote:  anyone help please, have a 2007 berlingo 1.6hdi, it has this rather annoying vibration when in lower gears or going from 3 to 4th at low revs, its not gearbox related its more of a vibration noise, not knocking like a worn antiroll bar bush etc, its recently just had outer tie rod ends changed on the steering rack and rear axle bushes changed as worn, the van will drive lovely anywhere but its really hard to explain, just after some advice as its booked in again to a garage to be checked over, the last garage did not find any engine mounts or suspension mounts worn or loose, its like a sound/rattle like something is loose somewhere!
Hi mate having similar problem with my van did you ever get to the bottom of what was causing this?cheers mate
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
