Threads: 7
Thanks Received: 1 in 1 posts
24-06-2021, 03:32 PM
(This post was last modified: 24-06-2021, 03:33 PM by radioman.)
Can anyone tell me how to remove the sidepanels in the back of my Berlingo 2018- 5seater van ?
Need to get access for tow bar cabling. Thanks in advance.
Threads: 2
Thanks Received: 56 in 52 posts
Thanks Given: 38
8
ex: 2003 1.4i cargo
Threads: 7
Ok, just had a few minutes to try. start with the bottom panel at the door opening. Remove it. Lift the floor mat just to see how the side panels are mounted. Remove the white inside panel along the left window, start from the back. Rip it carefully free from the bottom then you can move the panel upwards so it comes free from the top plastic pin.. Now you can see that the grey panels are fixed with screws which hwere hidden by the white panel.
I'll take a few pictures later.
The following 1 user says Thank You to radioman for this post:1 user says Thank You to radioman for this post
• boop
