28-06-2021, 06:35 PM
Hi, new to the forum. I've just fitted some rear parking sensors to a 2003 (M59) Citreon Berlingo Multispace. Having removed the rear light on the RHS to expose the wiring loom, I found no's 4 wire to be the live when reverse selected. I therefore scotch clipped this and with the red wire on the sensors and the black directly to the earth on the body. The reversing sensors operated fine until the car wouldn't start the next day. This had obviously drained the battery. I disconnected the reverse control box from the 2 wires provided and it still drained the battery, so the control unit not at fault. Is there another wire on the light loom that should be connected instead of no's 4??? Cheers for any help.
