[Engine] Turbo oil leak
Afternoon all,
Noticed a little oil dripping from the sump pan. Only a couple of drops but still, a leak. Investigated and found the oil feed pipe from the top of the turbo was a bit black with the stuff. Took the top banjo off and found that the pipe into the collar was loose -couldnt pull the pipe out but it could be wiggled and moved around in the collar. Put it back together again and ran back down from Carlisle to home(360 miles at a nice steady 58mph) stopping a couple of times and it was sound with no more seepage. It also seemed a bit loose on the bottom banjo where the gauze filter is. Surely those crimps should be solid.
Any ideas ?
(29-06-2021, 12:43 PM)pluggit1 Wrote:  Afternoon all,
Any ideas ?
There are not supposed to be solid, as wiggle room is needed. The only requirement for these is the outlet pipe to be centered. If it is touching the sides of the banjo bolt, it will weep. There were specific angles for the tightening, but I can find it later on. It is shown in more details here: https://www.youtube.com/watch?v=QHY_uPbPfyg
2011 B9 DPF warning light
Yesterday 11:52 PM
Fuel Gauge trouble
Last Post: Pricklybuzzz
Yesterday 11:48 PM
Hello
Yesterday 11:43 PM
Any advice regarding boot carpets being wet!?
Yesterday 05:50 PM
» Replies: 21
Yesterday 10:53 AM
Frequent DPF REGEN's
17-01-2025 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
17-01-2025 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
17-01-2025 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
17-01-2025 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
