wrong outside temp on display
My main display keeps giving me the wrong temperature reading, like on a bright sunny day it says -6 , any ideas why?
             curly
(29-06-2021, 07:15 PM)curlywurly71 Wrote:  My main display keeps giving me the wrong temperature reading, like on a bright sunny day it says -6 , any ideas why?
             curly
Has it always been wrong or did it just happen and is it always the same temp displayed (-6)? Might be a faulty sensor. On the M59 they are in the driver's mirror, not too sure on the B9, but I suspect it will be the same position, others might advise otherwise. Pretty cheap sensor and not too difficult to test/replace.
             curly
It happens on and off, but only in the last month or so and can suddenly go from 15 to -6 in a dip in the road and for no apparent reason.
It could be a faulty connection in the door loom and/or the actual sensor. If I am correct in assuming that the position of the ext temp sensor is in the driver's mirror, then the connection pins are probably described in this thread: https://www.berlingoforum.com/thread-4053-page-2.html (bear in mind this is for the M59).
Can someone correct me if I am wrong to assume that the ext temp sensor in the B9 is in the driver's mirror?
You can probably measure the resistance in the ext. temp sensor from the door loom's pins and see if it fluctuates. The resistance should decrease as the external temperature increases. It is probably a linear function of the temperature, measure, plot and see if it behaves accurately. Then you would know if it is the sensor itself or somewhere past the door loom.
[-] The following 1 user says Thank You to saskak for this post:
  • curlywurly71
the temp sensor is in the mirror, passenger side for LHD or driver side for RHD.
If you like gaming visit GameForest
[-] The following 2 users say Thank You to deejay_xb for this post:
  • curlywurly71, saskak
(30-06-2021, 05:18 PM)deejay_xb Wrote:  the temp sensor is in the mirror, passenger side for LHD or driver side for RHD.
Thank you deejay. That's what I thought, there would be minimal differences between the successive model versions. Basically the driver's mirror. The same with the M59, the driver's mirror is the one without the motor to operate the mirror, hence the missing motor connection pins can be used for the ext temp sensor.
If the mirror in the B9 is motorised, then it is different pins for the ext temp sensor.
  • curlywurly71
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
