Problem with reverse parking Aid ?
Hi all I have a Citroen Berlingo van B9 2010 it is fitted with factory parking aid
I have used my Lexia diag box and there's no problems reported saying no faults I have checked the fuse fine checked wiring fine changed parking ECU fine no difference tested all 4 sensors there fine
So I'm wondering now where the beeping sound comes from is there a reverse parking aid buzzer fitted on these if so where is it please
Or if someone has any other ideas please tell
Cheers Leo
I don't have factory fitted parking sensors, mine are aftermarket. I'm pretty sure they come through your speakers on factory fitted and it's interlinked with the radio through the bsi....I'm sure someone will be along soon to help further.
2012 Berlingo multispace Plus 1.6 with boot jump  Smile
I had problems with my factory fitted system a while back on my car (M59) have a read through the thread it may help you.
https://www.berlingoforum.com/thread-14182.html
On mine the beeping sound comes from a small speaker located next to control unit (parking ECU) which is behind the interior panel of the left wheel arch.
The sensors in the bumper give off a faint ticking noise when active, you have to put your ear right next to each one to hear it.
To test them engage reverse gear and with the engine running listen to each sensor for this ticking sound, note that on my system the sensors were not active with just the ignition on, the engine had to be running so you will need a helper to check them.
Thanks for the replies guys I'll look in to that further some good info to crack on with I'll keep you updated how I get on
Hi right update yesterday I removed all 4 sensors again and fitted them back but now all 4 are ticking but I still dont have any beeping noise so there has to be a separate buzzer somewhere on the van
So is there anyone on here with the same age van with factory fitted parking aid can tell me where the noise is coming from so I can find my buzzer?
Is this any help ?
https://www.berlingoforum.com/thread-12710.html
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
