[Engine] Running rough misfire black smoke more when engine hot
Hi I have a problem with my berlingo van 1.6 hdi 2010 when cold it runs not so bad but smokes black sooty crap out the back when hot it starts missing lag in acceleration and more black smoke but tick over it great and smooth still there are no codes popping up at all
Work I've tried so fare changer maf changed crank sensor tested egr valve and pin moment on lexia can here it working changed oil oil filter diesel filter air filter
I'm running out of idea's any help apricated
Can you check the boost pressure, rail pressure, airflow etc via Lexia & see if anything looks odd?
(04-07-2021, 01:51 PM)cancunia Wrote:  Can you check the boost pressure, rail pressure, airflow etc via Lexia & see if anything looks odd?
Hi possibly but I'm not that familiar with it yet played with it for hours on end and keep finding new things lol
Just an update all lexia readings where fine apart from 3 things going invalid value for the EGR when revved so I put a cleaner through the air system and the smoke has halved and the van is running better but not great so would you agree that it points to the EGR valve been faulty even though there are no fault codes popping up for it
(09-07-2021, 08:32 PM)majestic Wrote:  Just an update all lexia readings where fine apart from 3 things going invalid value for the EGR when revved so I put a cleaner through the air system and the smoke has halved and the van is running better but not great so would you agree that it points to the EGR valve been faulty even though there are no fault codes popping up for it
What do you mean by invalid value, is Lexia showing invalid values for the EGR when revved?
Cleaner through the air system would not be so good, try taking the EGR valve off and cleaning it properly. Might as well recalibrate it with Lexia after cleaning it.
Yes lexia readings giving invalid value readings for the EGR when revved I used EGR cleaner and it helped but still a bit to smoky and some hesitation at low speed then turbo kicks in and it go's like a rocket
Getting to the EGR on my van is a nightmare hence cleaning without removing I just need to make sure its faulty before I buy a new as id go for genuine valio EGR and don't want to waste any more money on this van
And yes I will recalibrate it forgot about that thanks
If I were you I would clean the EGR before buying a new one. They are rather expensive and it is a hit and miss with these. It might be full of carbon (likely, but depends on the mileage) and stuck on the open position, hence potentially you could get constant flow of air that does not have very much oxygen in it. The ECU though should report this as an error, so that is a bit weird that you do not have a fault recorded.
My replacement one was Hella and I am pretty happy with it, no errors and working flowlessly for ~3 years now.
(09-07-2021, 10:58 PM)saskak Wrote:  If I were you I would clean the EGR before buying a new one. They are rather expensive and it is a hit and miss with these. It might be full of carbon (likely, but depends on the mileage) and stuck on the open position, hence potentially you could get constant flow of air that does not have very much oxygen in it. The ECU though should report this as an error, so that is a bit weird that you do not have a fault recorded.
Hi the mileage is 154.000 miles its just such a big job to remove it to clean then put it back to only find out it never worked that's what's bothering me I'm not in good health so would probably lay me up for days lol
I can get a brand new Valeo EGR for £95 so not to bad I guess
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
