Threads: 3
Thanks Given: 2
Hello,
I have a problem with my Berlingo. When the car is at idle, slow driving and in steep hills the car wil overheat.
If i put on the heater in the car on full, temperature will go down abitt.
Annyboady have some tips on what can be wrong?
(Sorry my bad language.)
Threads: 123
Thanks Given: 250
34
Maybe the water thermostat is stuck closed?
Threads: 25
Thanks Received: 27 in 26 posts
Thanks Given: 16
6
AFAIK 'modern' thermostats 'fail safe', IE they stick open. It sounds like maybe the fan isn't cutting in, if it doesn't overheat when driving and there is airflow through the rad.
You can check the 'stat by running the engine from cold and feeling the top hose, it will be warm and then suddenly come hot when the 'stat opens.
May sound obvious, but I take it you have checked the coolant level?
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Thanks Given: 39
13
I guess you could run a temporary supply to the fan to check it.works You could also check that there is a supply to the fan when the engine gets hot. I never had this problem but think there might be a relay involved with the switching that you could check
Threads: 25
Thanks Received: 47 in 29 posts
Thanks Given: 23
How high does the gauge go ? I thought my fan was not working as the temperature would go over half way so I used to turn on the heater full blast to help it . but once when I did not notice the gauge going up the fan did cut in eventually .
Threads: 3
Thanks Given: 2
Well, i have never let it go up to more than a 105/110.
Threads: 25
Thanks Given: 23
I think the gauge on mine gets to around 100/110 (top 1/4) before the fan cuts in but drops down to normal within minutes.
