Lexia Diagnostic - fault?
I bought a generic Lexia diagnostic but I can't seem to get the computer (an old XP laptop) to recognise the device at all. I think I've been through every permutation of software install and the interface checking programme - nothing.
It is possible I've done something wrong or there's a fault with the laptop, but could someone confirm whether the green light on the dongle should stay on when it's plugged in to a USB port? The one I've got comes on for a second or so and goes out.
The green light on mine stays on. It could be a faulty device. Maybe try on a different computer to see if the light behaves the same or a different USB port.
[-] The following 1 user says Thank You to saskak for this post:
  • patchoulian
If you look in the XP device manager, you should be able to see the 'Actia' interface. If not, it's either a broken USB port or a broken interface. If you've just bought it, I'd be tempted to send it back in any case as faulty.
  • patchoulian
(27-07-2021, 07:11 AM)cancunia Wrote:  If you look in the XP device manager, you should be able to see the 'Actia' interface. If not, it's either a broken USB port or a broken interface. If you've just bought it, I'd be tempted to send it back in any case as faulty.
Many thanks both - no device in device manager, and tried it on different machines and the light doesn't stay on. I've raised a query with the seller.
Last Post: Carlos_sc
Yesterday 09:59 PM
Last Post: stu76
Yesterday 07:16 PM
Last Post: stu76
Yesterday 07:09 PM
Last Post: BLINGO BOMBA
Yesterday 02:18 PM
16-08-2026 08:18 AM
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: BigVtwin996
09-08-2026 12:10 PM
