Anti pollution tank maximum level reached
Hi
Had my stepson plug his laptop in to the Berlingo to try and I’dentify why I’m getting fault code P3008 which as far as I can tell is Air flow Restrictions.
This mess age came up when he tried to analyse using the Wurth Diagnostic software. I’m wondering how best to proceed. Would it be possible to regenerate the DPF using something like Lexis software. Or do I have to take to a garage to have it cleared and reset ?
Thanks for any replies.
PS 2013 multi space XTR 90 bhp 220000 mile on the clock
From a quick search around, P3008 looks to be connected to the MAF or crankshaft sensor rather than DPF. I think you need to get someone with access to Citroen Diagbox to scan for faults.
Thanks for that
Their was another code relating to the DPF which appeared when the laptop was plugged in. I’m going to take a chance and try one of those spray cleaners off eBay, the one which comes with the plastic hose you plug in where the Pressure sensor goes. If that doesn’t work I guess I’ll have to have the sensors looked at.
With 220k miles, there's a fair chance that the DPF is a bit clogged. With the Diagbox software you can force a regen if the Wurth does not have that feature.
Thanks Again
He’s going to take to his work tomorrow night and try Ito get Snap on Diagnostic they have their.
Last Post: Carlos_sc
18-08-2026 09:59 PM
Last Post: stu76
18-08-2026 07:16 PM
Last Post: stu76
18-08-2026 07:09 PM
Last Post: BLINGO BOMBA
18-08-2026 02:18 PM
16-08-2026 08:18 AM
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: BigVtwin996
09-08-2026 12:10 PM
