07-08-2021, 07:35 AM
Putting this up as a new thread as after reviewing all the youtube videos and other posts on this, I cant find anything where things actually discuss the upper column. The noise is plainly rubber or metal/rubber contact and is coming from the upper areas. It has started since I've been trying to solve the lower UJ issues.
I'm wary of the air bag but have taken off the plastic shrouds to top and bottom of the steering column/ignition key. I've used some silicone spray at the base of the wheel but that didn't work. I cannot see how this noise could be "transferred" from top mounts as others have seemed to suggest.
What I would like to get advice on is whether, if the steering is direct and power steering works, is it dangerous to continue to monitor?
Is there anything I can access by taking the horn push area off and is that easy to do?
56 plate HDi 1.6
56 plate HDi 1.6
