Osram Nightbreaker 200 - any good?
I miss the LED headlamps of my Suzuki and find the Berlingo lamps need greater light output and a whiter beam for my eyes.
These seem to be a possible improvement.
Anyone find them an improvement over the standard lamps and did the headlights require some sort of realignment for the ADAS auto dip system?
2021 Berlingo Flair M (K9) 130D
I.T. is there to help, but unforgiving if you make a mistake
I use Osram Nightbreakers in my B9 Berlingo and find them a good improvement, both in brightness/penetration and also a better shape dip cut-off. There are several versions of Nightbreakers now and I can't be 100% sure which I chose. Its a straight trade-off with the different versions more light vs less life, and as I don't do big mileage or lots of night driving the reduced life doesn't worry me particularly.
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
[-] The following 1 user says Thank You to Matt Haigh for this post:
  • uk_friendly_fire
I found this on the web https://www.carbuyer.co.uk/tips-and-advi...o-buy-2021 . Thanks Matt as a result of your post and reading this report I decided to invest in a pair.
Guess which headlamp has the Nightbreaker in it?
Attached Files Thumbnail(s)
Has anyone tried these two before, sorry for German site?
https://www.osram.de/am/night-breaker-led/index.jsp
https://www.philips.de/c-e/au/autolampen...ility-list
I fitted a pair around eight years ago and one popped last night on the way home
They've been ,err,brilliant...
Reorded some this morning.
I'm a cheap skate and buy the Osram long life bulbs, the headlamps of the Berlingo are pretty good compared to a lot of cars and I've never had an issue. Legal headlight bulbs give the same output otherwise they wouldn't be legal. The difference is the colour and the filters used on the bulb plus they burn hotter to get that white light. They also don't last as long and are prone to breaking if you hit a pothole etc. Steer clear of blue bulbs, eyes have difficulty in seeing any blue in the light spectrum in the dark. Incidentally the LED's are something else on my Ford better than HID's I had on my previous car.
I've fitted some Nightbreaker 200's to my K9 and am well pleased, a couple of years ago I commented on this thread that I'd fitted them to my previous B9 and noted the improvement. The only potential downside is that the lifetime is lower than a standard bulb but I'm not in the big miles night time driving category
Matt
   previous
Ho avuto tre Peugeot Partner e sempre montato lampade Philips Racing Vision o Osram Night Breaker e danno un pò di luminosità in più. Ora sul nuovo Berlingo ho messo delle lampade a led 'canbus' che sostituiscono perfettamente le originali ma è tutta un altra cosa! Le trovi anche della Osram omologate!
(30-10-2023, 05:09 PM)BEAR1962 Wrote:  Ho avuto tre Peugeot Partner e sempre montato lampade Philips Racing Vision o Osram Night Breaker e danno un pò di luminosità in più. Ora sul nuovo Berlingo ho messo delle lampade a led 'canbus' che sostituiscono perfettamente le originali ma è tutta un altra cosa! Le trovi anche della Osram omologate!
Google Translate converts this to:
"I have had three Peugeot Partners and always fitted Philips Racing Vision or Osram Night Breaker lamps and they give a little more brightness. Now on the new Berlingo I have put 'canbus' LED lamps which perfectly replace the original ones but it's a completely different thing! You can also find them from Osram approved!"
Today 09:56 PM
Yesterday 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
