Threads: 3
Thanks Given: 1
Radio/Touchscreen reboots periodically mid-drive. Sometimes never, sometimes every minute. I've removed the unit and re-seated all the connections (no obvious issues).
what do I check next?
Regards, Pat
65 plate 2015 Berlingo Multispace XTR Blue HDi 1560CC Diesel Automatic
Thanks Received: 2 in 2 posts
Thanks Given: 2
Needs an update
Threads: 36
Thanks Received: 4 in 4 posts
Thanks Given: 19
Spray contact cleaner on the connectors?
2021 Berlingo Flair M (K9) 130D
I.T. is there to help, but unforgiving if you make a mistake
Threads: 7
Thanks Given: 10
20-08-2021, 10:10 PM
(This post was last modified: 20-08-2021, 10:11 PM by RafM.)
2016 XTR Blue Hdi - had the same problem, seems to have been cured by a dealer
software update last week.
Threads: 53
Thanks Given: 147
7
Mine used to do this back in the days when I was connecting by Mirrorlink, I've never upgraded the radio (and I don't think the dealer did at service) and it hasn't done it in the over one year that Mirrorlink stopped working for me.
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 0
Thanks, yes could be linked (or rather unlinked!).
It all went wrong after I connected an iPhone (with an original cable)!
Mirror link is lost to me now. I think it has the original firmware so it must be due an update anyway.
Fingers crossed!
Matt
Finally I have discovered the perfect Car!
Chuckable, muckable, loveable Bertrand le Bleu
Berlingo MS XTR BlueHDi 100 65 plate
Threads: 3
Thanks Given: 1
UPDATE - still doing it even having had a really good check of the contacts. I guess firmware updates are the only option! I'm a software engineer by trade, so plenty brave enough - any ,links to the firmware and method would be appreciated.
Pat
Threads: 0
Sorry if I’ve said this this before (I blame getting older!) but have an update.
I’ve been to my local Citroen dealer. They were helpful, did a diagnostic check and updated the firmware of the unit. £60 but everything on the display seems to work fine now. It doesn’t have SatNav but I expect that I don’t have internal GPS anyway. Bluetooth is surprisingly efficient, esp when using phone as SatNav and other functions.
One thing I can’t seem to see is the current Version of the update.
It now even shows “Car Play”, so I know they’ve updated the system, but trying that says I need to have that specifically installed by the Dealer. Not sure if I’m missing anything by not having that. Have seen mixed reports!
Not sure about the links to the firmware. When I tried earlier ones in thread and elsewhere the links were shown as “expired” so up to date links would be good & useful in the future. Although I’d need a bit of an idiot’s guide to updating (although I do get the general theory).
(Still loving my ‘lingo!)
Matt
