Interchangeability of front springs..?
Hi. Looking for a bit of advice... Have set about replacing the front coil springs on my 2006 Berlingo (actually Peugeot Partner) MPV - when I check out replacement springs online (using the vehicle reg) I am generally getting two options - for vehicles with/without A/C... my vehicle has A/C but the existing springs are different to the image for the A/C version and identical to the non-A/C replacements..! How important is it that I use the right ones - are they interchangeable..? Thanks. Guy
The springs differ in stiffness depending on the weight of the vehicle, the engine type, Air con, panoramic roof will all play a part in the overall weight of the vehicle.
I was advised by the technical department at KYB to use their RA1330 springs on the front of my car, it has AC & the panoramic roof.
You can find the KYB spring catalogue at the link below.
https://kyb-europe.com/wp-content/upload...prings.pdf
KYB are good quality springs, you will find them listed on ebay for a good price.
  • Guy D Pearson
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
