Diesel Power Sport 4. Help required please.
A neighbour of mine has given me some Diesel Power Sport 4 ( Millers Oils ). It helped improve the running of his Talbort motorhome which he has since sold.
Thinking about trying some in the Berlingo van. Anyone used this before?
If I were to put 10 litres of diesel in my van, how much of this additive would I need, it says use in a ratio of 1000:1 but I am getting brain freeze. 1 litre of diesel is equivalent to 1000 millilitres, therefore if I put 10 litres of diesel into my tank thats 10,000 millilitres, so I would need 10 millilitres of additive. Have I worked that out correctly Confused
Many thanks
Attached Files Thumbnail(s)
(18-08-2021, 07:09 PM)Sierra Charlie Wrote:  A neighbour of mine has given me some Diesel Power Sport 4 ( Millers Oils ). It helped improve the running of his Talbort motorhome which he has since sold.
Many thanks
Yes, 10ml in 10L diesel is correct. That must be some concentrated thing.
[-] The following 1 user says Thank You to saskak for this post:
  • Sierra Charlie
Thats the same ratio as Millers Ecomax 50ml treats 50 litress
[-] The following 1 user says Thank You to Tree for this post:
  • Sierra Charlie
Many thanks
Thank you very much saskak for your reply and the confirmation of my mathematics Wink
I too thought the dosage meant it was probably heavily concentrated hence the query, also to get opinions on the product. As mentioned previously my neighbour used it in his Talbot Express campervan. With such small dosages no wonder there is still over half a can left. Still it ought to be decent stuff judging by the expensive price tag.
(19-08-2021, 09:01 AM)Tree Wrote:  Thats the same ratio as Millers Ecomax 50ml treats 50 litress
Thank you very much Tree for the confirmation reply and the comparison with Millers Ecomax.
Many thanks
No worries, but I would be a bit wary of how old the liquid is. The active chemical components inside will degrade with time, it is just inevitable. It might have lost its active components, but I have no experience with this particular one, so I might be just talking out of my back.
Many thanks
Never thought of that Rolleyes , certainly be worth asking a discreet question next time I see him Wink
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
