  • 1 Vote(s) - 4 Average
dash clocks
hi need help does anyone know if you can replace the instrument panel as JUST ! the clear bit is busted i have no idea how this happen it was like this when i bought the car . [Image: 238126469_545652826766034_55193190747021...e=6148E661]
(23-08-2021, 04:01 PM)daz13 Wrote:  hi need help does anyone know if you can replace the instrument panel as JUST ! the clear bit is busted i have no idea how this happen it was like this when i bought the car . Its a  2.0 hdi 2004 mulitspace would post a pic but computer on one AGAIN !  Angry
You can replace the whole instrument cluster with a new one, although if the new one has higher milleage then this will overclock your car!
If only the clear bit/screen is busted, you can just replace the screen without replacing the whole instrument panel. Not too sure if you can buy just the clear screen, but you source it from a scrappy or buy the cheapest instrument cluster from ebay for example.
If you can get the old plastic out to use as a template you could cut out a new one from suitable thickness perspex/acrylic sheet (2mm?) using a jigsaw with a very fine tooth set at low speed - if necessary clamped between 2 bits of thin plywood to prevent cracking.
Changed mine for one out of a diesel 206,
it was plug and play, and I prefer the white on black layout.
If it's the same engine, you should be in luck.
BUT as warned, your car will absorb a higher mileage from a fitted set of clocks,
even if you put your lower mileage originals back.
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
