Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
In recent weeks when the engine (and heater) get nice and warm there is a smell coming from the vents.
It smells exactly like beef sandwiches!
If you turn the heater off and close all the vents the smell goes.
Has anyone else come across this? Seem to remember a mates Cortina did the same thing in the 1980's. (Don't remember alot from the 80's...)
The problem is that eveytime I drive now the smell makes me feel hungry, I have to stop and eat and am starting to put weight on.
Should I start by draining and flushing the cooling system?
If so, what specification of antifreeze do I use when re-filling?
And what quantity/percentage for our temperate climate?
Threads: 63
Thanks Given: 410
Martin, Try the sandwich shop in Penkhull opposite the church. Superb bacon and egg sandwiches/baps/sticks. Could just go one now but closed on Sunday.
Sounds like your heater matrix could be on its way out so you could combine the sandwich shop with a trip to our motor-factor friend in Trent Vale
Threads: 52
Thanks Given: 87
5
That's got to be a smell like a French Dip beef sandwich I bet (being a Citroen)
Threads: 101
Thanks Given: 384
Pollen filter seems like a good place to start.
There is no coolant loss; have been checking regularly.
The smell is most strange.
Not diesel, exhaust, oil, clutch, brakes, etc.
Nothing vehicle related at all; definately beef sandwiches!
Threads: 63
Thanks Given: 410
Me old 306 used to give out a smell like curry quite regularly and I was told that that was the heater matrix on its way out...5 years later it was still going strong and there was no loss of coolant...
All these strange cravings, sure you are not.... nah, don't think so:whistle::whistle:
illyme:
illyme:
Threads: 20
Thanks Given: 2,126
18
No Aircon? How dare you.That's stuffed all our theories out the window.The only thing I can think of is crud in the plenum chamber.Check it's draining properly by pouring a SMALL quantity of water in it & looking under the rear of the front wings.Then lift out the grille & check for sediment.Normally it would smell musty/composty,but you may have different flora in sunny Staffordshire.Good luck & let us know the remedy.
Strawberry flavoured windows
