Threads: 12
Thanks Received: 3 in 3 posts
Thanks Given: 2
Now having found its not an MOT item, is it possible on the 03-09 Berlingo and Partner models to disable the seatbelt warning on via Lexia or whatever?
thanks...
Threads: 123
Thanks Given: 250
34
IIRC you can disable the 'chime' warning, not sure about the light though.
Threads: 9
Thanks Given: 2
cut the little wire that goes into the catch on the side of the seat
2014 B9 1.6 HDI Multispace.
Threads: 19
Thanks Received: 30 in 29 posts
Thanks Given: 12
12
Wear the seatbelt properly. It would normally go off then.
Now a 2019 K9 1.2 petrol.
Threads: 7
Thanks Received: 26 in 24 posts
option was there on lexia on my B9
